new boiler - buderus vs viessmann vs peerless?
tom_randall
Member Posts: 1
in Oil Heating
I have 3 quotes for a new oil boiler -- any advice? are these comparable? do I need more information, and if so, what?
1- "Peerless WBV03WPCL oil fired cast iron boiler"
2- "Buderus G-115/4 boiler with burner"
3- "Viessmann VR1-27 oil boiler and Viessman VR1-27 Riello oil burner"
ALSO, one quote includes replacing the value (firomatic B104CF flare
angle valve) and circulator (grundfos alpha 1555FRLC var. speed
circulator) but the other two don't. Is it a good idea to replace those?
my thoughts
I LOVE the Viessman burner which isn't what you asked, but I am throwing it out there.
Viessman is the current state of the art boiler/burner set-up in my opinion.
the downside is the price
Peerless is simple and sturdy and attractively priced.
I like them and sell loads of them to price sensitive customers.
Buderus with the logomatic control is the best value out there
for a triple pass boiler w/ outdoor reset ,
its a nice compromise between the other two
still a bit pricey but the savings of operation will pay off in the long run.
I hope this helps
Always replace the flared firomatic with any new boiler,
its so automatic I leave it out of proposals
packaged boilers come with one new circulator,
now is a good time to replace them all
Ask the ones who didn't adress it to include it, I bet they both say OKThere was an error rendering this rich post.
Buderus or Viessman
I would go with the Buderus or Viessman both very good triple pass boilers. When I replace a boiler I cut the pipes and replace everything valves, expansion tank, circulators etc. Not changing other components when changing the boiler is like buying a new car then asking if you can take the old tires off your old car and put them on the new car to save a buck.There was an error rendering this rich post.
well said Aaron
from the ceiling down. Start from scratch so you can stand behind your workmanship. If they want to wheel and deal, call someone else0
- 167 Indoor-Air Quality
