Water leaking from glass gauge
nycpa
Member Posts: 108
Hi, my glass gauge for my weil mccaan steam boiler is leaking from the bottom. I turned it with a pylor and that seems to help for a while. This must be my forth time tightening it this season. This time i noticed a crunch sound, possibly dirt in there. I wanted to replace the black rings at the bottom of the glass and wipe it clean. Do I need to replace the glass, means buying glass and a cutter or just the black ring will do? Thanks
Do it carefully
If you want to replace the gauge glass washers you will have to close the brass cocks above and below the tube and loosen the nuts that hold the tube in place. Work carefully so you don't break the glass but I would recommend having a new one on hand just in case. If you can't find the glass or washers locally you can order them from Mcmaster Carr http://www.mcmaster.com/#gauge-glass/=ry4ze3 they have several sizes available that are pre cut.
Remove the tube carefully and make sure you clean any old rubber off the tube and the brass nuts.Put the new washers on the glass and install it, tighten the nuts carefully so you don't crack the glass.
3PSI gauge0 -
Thanks
Thanks for the advice0 -
Mine too
Mine did this too on a pretty new system (3 years old I think). I took in apart, cleaned the gaskets and everything else, and put it back together tight and it's been good since.
I think the fact my water was about 75% rust contributed to the gaskets leaking. And the pressure was 3 PSI+.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 117 Chimneys & Flues
- 111 Geothermal
- 163 Indoor-Air Quality
- 72 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 15.5K Strictly Steam
- 55 Water Quality
