beckett aqua smart
zepfan
Member Posts: 458
in Oil Heating
I had a few questions regarding the beckett aqua smart control. first how long do they normally take to install on an existing oil fired boiler of appx. 20 years of age? do they really provide a savings in fuel usage? I know that this control is now used by beckett to replace the heat manager that they, beckett, have stop making. we have a customer that has high fuel usage and I was looking at installing one of these on their boiler. thanks to all
Questions
How well insulated and air sealed is the home? Is the boiler running close to it's rated efficiency? Could there be a leak in the oil return line if it's two pipped? If the current boiler is using a triple aquastat then the change should be pretty simple. But if the home's oil consumption is unusually high then I would look to see what is causing it.There was an error rendering this rich post.
- 120 Geothermal
