Anyone know the manufacture of this steam trap
Andy Stack_3
Member Posts: 39
This Y- Strainer and steam trap are on small air handlers on a old vacuum system.
Hi Andy.
Not sure if this helps you out or not, but it looks strikingly similar to Anchors venturi steam trap. http://anchorelite.com/Steam/VenturiTrap.htmlgwgillplumbingandheating.com
Gerry
Thanks Gerry that is the one.0 -
Gerry
Steam trap is Made by STEAMGARD dba Engineering Resources, Inc (ER)
I wish I saw this post sooner to answer your question. That steam trap in question is made by STEAMGARD LLC. STEAMGARD used to be called Engineering Resources Inc. Hence the ERI stamp on the steam trap. That steam trap you have uses a modified venturi nozzle for effective condensate removal. Take a look at steamgard's website for more details/contact information- www.steamgard.com. Take Care- Tony0 -
Made by STEAMGARD dba Engineering Resources Inc
- 50 Industry Classes
