Anyone know the manufacture of this steam trap
This Y- Strainer and steam trap are on small air handlers on a old vacuum system.
  • gerry gill
    gerry gill Member Posts: 3,078
    Hi Andy.
    Not sure if this helps you out or not, but it looks strikingly similar to Anchors venturi steam trap. http://anchorelite.com/Steam/VenturiTrap.html
    gwgillplumbingandheating.com
  • Andy Stack_3
    Andy Stack_3 Member Posts: 39
    Gerry
    Thanks Gerry that is the one.
  • Andy Stack_3
    Gerry
  • TonySt
    TonySt Member Posts: 2
    Steam trap is Made by STEAMGARD dba Engineering Resources, Inc (ER)
    I wish I saw this post sooner to answer your question. That steam trap in question is made by STEAMGARD LLC. STEAMGARD used to be called Engineering Resources Inc. Hence the ERI stamp on the steam trap. That steam trap you have uses a modified venturi nozzle for effective condensate removal. Take a look at steamgard's website for more details/contact information- www.steamgard.com. Take Care- Tony
  • TonySt
    Made by STEAMGARD dba Engineering Resources Inc
