By special request.
DanHolohan
Member, Moderator, Administrator Posts: 16,713
in Plumbing
About those things a plumber must know? Let's see:
1. Water flows downhill
2. Cold's on the right; hot's on the left
3. Don't bite your fingernails.
I forget the rest. Feel free to jump in.
Retired and loving it.
Water
Water is not the only thing that rolls downhill! And payday is Friday!0 -
Like Mark Eatherton Says
I got pumps that will make water go uphill...To learn more about this professional, click here to visit their ad in Find A Contractor.0 -
plumbing quote
righty tighty lefty loosey0 -
Every time...
I begin to think I'm a pretty smart guy I find myself in a place like this!0 -
Always
close the drain before taking the faucet apart!0 -
shirts
!. Keep your dang shirt tucked in!
2. Look around and ask lots of questions. And get lots of training.
3. Always assume there is more of a problem than you think. Keeps you from fixing the "problem" and leaving, only to find the other one on the recall.
4. See #10 -
William of Ockham
To rick of Alaska: I humbly beg to differ. One of the best "tools" I have ever acquired in my career is "Ockham's Razor," compliments of William of Ockham, a 14th cent. English philosopher/logician. Its a logically elegant principle of problem solving. Basically: start with the simplest fix, FIRST. E.g.: If your car stops running--check the gas gauge.
I use the "Razor" almost every day.0 -
#1 Rule:
99,9999% of intermittent water leaks through a ceiling with a bathroom above it is from some form of water getting through the walls around a tub or shower or a leaking shower valve.
Never take down a ceiling unless there is water steadily leaking through the ceiling.0 -
ockhams razor
Whole heartily agree with that. What I was saying is just don't assume that when you find the basic problem that you are done. There might be a second issue that is not apparent until the first problem is fixed.
Rick
p.s. I also use the same problem solving sequence myself. Start with the most likely problem and then go from there. Gets me to where I need to be.0 -
payments
Collect you payment as soon as you are done before the customer forgets how important it was to have you out there right now.
Be polite.
Clean up after yourself.
Tuck your shirt in!!!
Pass along the knowledge.
Rick0
- 120 Geothermal
