gorton valves
alliance
Member Posts: 3
i have a steam system, when the boiler shuts off and the radiator cools slightly, the valve makes a loud sucking noise, like a vacuum...any idea to what the problem may be?
Noisy vents
Radiator vents expel air when heating and draw in air when the boiler turns off. Your vent sounds as though it's doing its job.
You will get more attention if you re-post in the "Steam" forum.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Loud sucking noise
The main (not rad) vents should be doing the big job of air removal, and vacuum relief. Post some pictures, and we can advise what replacements or additions may be needed. Noisy vents indicate a lack of main venting capacity.--NBC0
- 167 Indoor-Air Quality
