Easy way to clean pigtail / siphon
ChrisJ
ChrisJ Member Posts: 16,815
I don't know if this has been mentioned before or not but I confirmed my pigtail was clear today by removing a gauge and blowing with my mouth.  This of course blew most if not all of the water, and any junk out of the pigtail and into the boiler to be drained when I clean the boiler.
It's not a perfect way but I feel it's a lot easier than taking everything apart and I like to know that things are functioning properly even if I never need them.  I test my pressuretrol once a year by closing the king valves and return valve allowing pressure to build.   I also test the LWCO occasionally which unfortunately is much harder with a probe type than a float type.
I did not add water back in after this as I feel the first time you make steam all that happens is the steam pushes against the air in the piping and in the process condenses and fills the pigtail.  I don't see a point in adding water.
  • KC_Jones
    KC_Jones Member Posts: 5,885
    I was thinking
    When I put my new boiler in I would put a union on both sides of the pigtail so I can easily pull it for inspection on a yearly basis, just because.  I figure it makes it easy to take it off and inspect.
    2014 Weil Mclain EG-40
  • ChrisJ
    Union
    Some of us forgot to put a union. :)
    Hey, at least I admit when I make a mistake, right?
  • vaporvac
    vaporvac Member Posts: 1,520
    Did that...
    Thanks  to suggestion here, I did put them on just that way and also on the kpressure relief valve. Since my Vstats are on my header they did need a pigtai, but I used them anyway! Pigtails rock, but the little ones are really difficult to find.
  • Techman
    Techman Member Posts: 2,143
    Pigtail
    I thought the water in the pigtail protected that sensitive diaphragm/ bellows in the control from the steam . I put in unions on my 1st routine on ALL of my steamers , total 4.
  • ChrisJ
    water
    Hi Techman,
    Yes, the pigtail blocks steam from getting to sensitive devices.
    OleksiiC
  • BobC
    BobC Member Posts: 5,523
    I agree
    The air in that sealed pigtail essentially blocks the steam from getting very far. the bottom of the loop in my pigtail gets very hot but the top of the pigtail never gets more than warm and I'm sure that's just because of the thermal conduction of the brass pigtail.
    Bob
    3PSI gauge
  • Pughie1
    Pughie1 Member Posts: 136
    Tee
    Chris,
    How about a Tee on top of the syphon, then your presuretrol/vaporstat (you must have a vaporstat) with a plug in the bull. Take out plug, fire boiler, if you get water or steam -- the syphon is clear. Just thinking.
    John
