Steam boiler questions
Justin192837
Member Posts: 1
Hello, this may be the wrong section but I sure hope I can get some insight on this. Anyway I've got no idea how much a steam boiler is worth that we've picked up. We do construction and was hired to fix up a closed down dry cleaning shop. There was this boiler left there. How much is this worth? Link to gallery of pictures: <a href="http://imgur.com/a/ARWUB#2">http://imgur.com/a/ARWUB#2</a> Thanks!
I've moved your post to this section.
It's a high-pressure boiler, used to make heat, to iron clothes in this case. You can't use it on a heating system for a building because its steam nozzle is too small for low-pressure steam. It's a used boiler and worth whatever someone is willing to offer you. It would help if you posted the location of the boiler. Thanks.Retired and loving it.0
- 15.8K Strictly Steam
