Navien combo
Snowmelt
Snowmelt Member Posts: 1,457
This is a job I did last year just wanted to hear any comments.
  • RobG
    RobG Member Posts: 1,844
    Does the
    Does the condensate drain onto the floor?  :)
  • Snowmelt
    edited March 2014
    Pump
    Cute, I added a three foot hose into a sump pump.
  • HomeOwner1
    HomeOwner1 Member Posts: 134
    How is yours running?
    Your install looks similar to mine. I just have some more pumps than you and control valves.
    Mine is going good so far. What kind of maintenance do you do on yours? Filter changes, etc? And how often?
  • HomeOwner1
    Exhaust Question
    Did you use CPVC or PVC for exhaust?
    Mine is just PVC, as per the manual when we did it.
  • Snowmelt
    edited March 2014
    Centro therm
    Not sure on the spelling do you have high heat coming out of your unit, if so you have to use PVC or Centro therm.
    This is an install job with one zone system.
    pops cpvc
  • john p_2
    john p_2 Member Posts: 367
    Would love to see pics of an install with baseboard zones if you have them.
