Navien combo
Snowmelt
Member Posts: 1,457
Does the
Does the condensate drain onto the floor?
Pump
Cute, I added a three foot hose into a sump pump.0 -
How is yours running?
Your install looks similar to mine. I just have some more pumps than you and control valves.
Mine is going good so far. What kind of maintenance do you do on yours? Filter changes, etc? And how often?0 -
Exhaust Question
Did you use CPVC or PVC for exhaust?
Mine is just PVC, as per the manual when we did it.0 -
Centro therm
Not sure on the spelling do you have high heat coming out of your unit, if so you have to use PVC or Centro therm.
This is an install job with one zone system.
pops cpvc0 -
Would love to see pics of an install with baseboard zones if you have them.0
