Used Cast Iron Radiators
Rob10667
Member Posts: 8
Looking for a good source for used cast iron radiators in the Midwest (Ohio, Indiana, Kentucky, Etc.) Specifically need two (2) 59" Long, (or a little shorter) 12" deep, 20" high. or as close as possible. Any help would be greatly Appreciated.
This site
has a fairly good list of Architectural salvage companies broken down by state. Often thse types of places have slavaged CI radiators.
http://www.oldhouseonline.com/where-to-shop-for-architectural-salvage/0 -
Dayton Ohio
Hi, I'm in the Dayton Ohio area and because of remodeling work am going to be removing a radiator that might be what you are looking for.
American-Standard Co., 3
column, 28 section, 22" tall, 62" long, for a 14280 Btu/Hr at 170
degrees.
It's currently connected to the system because of cold weather stopped the house work.
So if you are in no rush for it...
I also post these things to the Craigslist of either Columbus or Cincinnati Ohio
harcourt377@att.net0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
