when to use NPT and when to use sweat
heatingFun
Member Posts: 84
I need 2 sets of circulator isolator flanges. There are two different types: NPT and Sweat.
Usually when we should use NPT and when we should use solder?
Do you think this isolator flange from Taco is good? <a href="http://www.sdsmarket.com/Taco_SF_100S_Shut_Off_Swivel_Flange_1_Sweat_p/sf-100s.htm. ">http://www.sdsmarket.com/Taco_SF_100S_Shut_Off_Swivel_Flange_1_Sweat_p/sf-100s.htm. </a> It seems different with others.
flanges
good for you at least you are using isolation flanges.I havent had problems with Taco flanges although I do prefer the Grundfoss model.Use solder if you are piping in copper or some people like to use blk fittings then go npt,good luck.0 -
Flange
Say your plan of mounting the circulatorsis off the boiler , for support of pumps better to build manifold in iron , then after you can pipe it in copper ..... say you have two circs in same size , buy a set of each .... if not use adapters ...On a hydronic wall , either or but support pumps with pipe champs ...I wouldn't support circulators in copper alone ...There was an error rendering this rich post.
Isolation flanges
can be mixed and matched if needed. It's not uncommon to see black iron on the boiler side and copper tube for distribution.
Webstone offers an amazing array of options http://www.webstonevalves.com/customer/wecoin/PDF/Isolator-Sell-Sheet-vf-web.pdf0
- 120 Geothermal
