Heat Transfer Plates over Onix?
Rob Blair
Rob Blair Member Posts: 227
Have a staple up job, not mine, that will not produce enough heat.
Has Onix just hanging.  Bubble wrap below, then R-19 fiberglas.
250 year old house with 20" stone walls.
I know they need supplemental but would like to get the floor heat working a little better.
Thanks,
Rob
  • SWEI
    SWEI Member Posts: 7,348
    You might want to inquire about
    the Watts FlexPlate (flexible graphite heat transfer plates.)  I was not impressed with the minimal contact they achieved with 1/2" PEX, but Onix has a larger OD (which I'm now thinking the FlexPlate may have actually been designed to work with.)
  • Rob Blair
    I have some Watts PLates
    I actually have some of those plates.
    Next time I am there I will try them out.
    Thanks,
    Rob
  • SWEI
    Let us know how it works out?
    I'm curious...
