reillo post purge
Paul_69
Member Posts: 251
in Oil Heating
i have a reillo f40 with a al 1009 post purge timer board and it is keeping flame on during post purge sequence and shuts off after timing is finished. wiring is correct and i think it is the board. any thoughts?
How bout the oil valve
Did you check to see if either the oil valve is still getting power, or is stuck open?There was an error rendering this rich post.
