Viega press sleeves
Robert O'Brien
Member Posts: 3,584
Does anyone make a comparable product? Viega discontinued selling the sleeves separately. TIA
Sleeves
Don't know if anyone makes a match, but I could give you some if you need Bob, Ill trade you some for that book,, LOL0 -
Nope
If you read the brochure on their site that is a completely different. Uses an expander ala Uponor but then a tool to slide the sleeve over the tubing and fitting.
It's a shame that the Viega sleeves are no more. A have a few dozen left. If you have to redo a layout and cut the fittings out, you can remove the pressed sleeves and reuse the fitting. Now the fitting is wasted.
If anyone from Viega monitors Heating Help I'd like to hear the reason these went away. I made an investment in the tools and love Fostapex, why remove a useful part of the system?0 -
sleeves
Heat Link sleeve will work with Viega.0 -
these look....
a lot like them...
http://www.siouxchief.com/products/supply/powerpex-systems/astm-f1807-and-2159/sleeves0 -
MikeyB
I apologize,send me your address and I'll get it out this week0 -
Sorry
It's Rehau that uses F2080, not Viega.
I really prefer the flow rates on F1960 & F2080.0 -
Press Sleeves
You can buy the Viega Sleeves on Pexsupply0
