High windows in heat calculations
mjcromp
Member Posts: 57
Do windows up at 8'-9' high play a big part in the heat-load calculations?
Absolutely...
They are going to be the biggest contributor to heat loss, unless you are dealing with cinderblock walls….
ME0
