Laars low water flow board
John Mills_5
Member Posts: 952
Got an old JVS-100 found cool. Would fire for 30 seconds off for about 2 minutes. Regular as clockwork. Traced it to the low water flow board.
NOW: when it wasn't firing the relay on said board was clicking on & off like a turn signal. The whole time. And when it did it sent a split second of voltage to the spark control which in turn sent voltage to the gas valve so one of the solenoids in the valve, guessing pilot, was also clicking on & off like a turn signal. Obviously not right.
So, do we have a flow issue? Bypassing the board to get heat on a below zero night, sure doesn't seem like it. Got the loops hot in no time so didn't appear to have a flow problem. Hate to order a new board to have it do the same thing (less the turn signal). Just started this.
Any thoughts? Thanks!
Is there
a senser conected to the board? Maybe it needs to be cleaned.0
- 86.8K THE MAIN WALL
- 56 Biomass
- 108 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 69 Pipe Deterioration
- 959 Plumbing
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
