Oil to Gas Conversion of HBSmith Boiler
Smithy
Member Posts: 7
Have a 30 year old HB Smith steam boiler in very good condition/ 5 sections BB14. Gas is coming to town and thinking of putting in a Carlin EZ Gas Pro conversion burner (replacing an oil fired Carlin). A competent local tech priced it out (and knows steam). Wondering if this is smart, it's a low cost option for conversion. Have a one-pipe steam system which I LOVE, plus pellet stove, Lopi and Rinnai for area heating. (I'm a multiple redundancy guy.)
Other option is a new Weil-Mclain steam boiler for about five times the price, whole new system, but keep steam and radiators. (I admire steam as a lost art form and think Dan Holohan's books are terrific!)
Yes
You won't get the efficiency that can be had with some of the best wet based boilers but you'll save enough dough to pay for a new boiler in fuel savings. As long as the old girl is in good shape I would do it. You can use the EZ-Gas in a new boiler if the old girl passes on.
The cost of natural gas is just to low to ignore. Just be aware you will need a stalnless steel chimney liner and the old girl will have to be cleaned real well before the install and after one season of use.
3PSI gauge0 -
Yahoo
Thanks for your reply. I do have a stainless steel liner in my chimney and that's a great approach - to use the venerable old HB Smith until it dies, and the Carlin (also a workhorse) survives to fire a new boiler.0 -
Pix
I know lots of you steamguys like pix. Here is HB.0 -
That is one FAT system riser
was this a vapor system?0 -
Huh?
I'm sorry to say I can't answer that question. But my 9 radiators all heat evenly and I have no water hammer.....0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 848 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
