National 'Aero" Cast Iron Convectors
heatseeker
Member Posts: 1
what convector can you use to replace "National Aero Cast Iron Convector" without having to replace the existing cabinets which will have same heating surface output ?
see attached photo
see attached photo
Convector conversions:
If it's hot water, probably any amount of coil convectors that you can stack in there to equal what you already have.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
