Riello F15?
hvac
Member Posts: 6
in Oil Heating
Does anyone know if the F15 Riello ever came with a hydraulic delay? I have a boiler thats been running for many years without a problem and is now having a problem with starting. The problem could definitely be non-related to the hyd. delay. I am just curious if this even belongs on the burner and why someone would put one on if it didnt come on it. Thank You
Rick Koester
Senior Technical Field Trainer
Ariston Group - NTI Boilers
IG @rkoeshvacny
hydraulic delay?
I have never heard of a hydraulic delay. I have seen the air shutter delay when opening, but that is because the jack wasn't getting pure oil. A mix of air and oil or foaming oil due to an oil restriction will delay the opening of the air gate. Here is a link to this burner's install manual.
http://riellotechlit.webs.com/documents/F-15%20HYD.%20JACK.pdfThere was an error rendering this rich post.
