ironfireman coupling
add
Member Posts: 94
Hi , I am having a hard time to find a Guardian-20 or -30 for a ironfireman pump coupling any info on who carries it, or can i use another brand that is similar, Rockland cty area , New York,Thanks.
Coupling?
Add, do you mean a spring coupling for pump?
Mike T.0 -
not a spring coupling
In actuality is like a residential coupling made out of hard rubber,but much thicker in diameter that you can cut down to your lenght. The set screws on each end are made of metal( pump side and burner motor side).I'll probably order directly from Guardian (there is minimum to spend in order to buy directly). Thank you.0
