"Precise" Vapor Radiator Valve
Steamhead
Steamhead Member Posts: 18,205
Saw this for the first time, on an Orifice system in southern Pennsylvania. It was made by a company called Haynes-Thomson of Philadelphia. The house it's in was built about 1918-1920.
The orificing feature of this valve is a limit stop in the ring that encircles the handle, working much the same way as a temperature limit stop in a shower faucet.
The unique dimensions of this valve mean that if you replace it with a valve of today's standard dimensions, you need an extension coupling.
Anyone else ever see this type of valve?
Consulting
  • JStar
    JStar Member Posts: 2,752
    Valve
    Never saw that one before. Pennsylvania is a gold mind of vapor systems. Looks like that valve has been wrenched on and off and few times.
