Riello 4.0
taz
Member Posts: 13
Burner runs shuts off on temp. Have to hit reset and bleed line for it to fire again. Changed filter ,tighten all fittings. What's next?
find vacuum leak
Do you have a buried tank? There is air leaking into your oil line from somewhere. Time to pull out the vacuum gauge and start looking.There was an error rendering this rich post.
