license help
jimw72
Member Posts: 4
hello all. i hold an S-2 in ct how would i go about getting a gas fitter license in mass?
Gas License in Massachusetts:
You need to call the State Board of Examiners of Plumbers and Gas Fitters and ask them. Its up to them as to how much credit they might give you and you will probably have to take a test. They make all the decisions.
Do The Google on the above term. It will take you there.0 -
gas license
I did exactly the same thing only it was an S1-MA Gas. You should get your S1 first because you can pull permits with it. In MA a journeyman gas fitter can pull permits in CT a journeyman cannot. Not sure if MA will let you apply/take the test based on an S2 but you can try.0
- 120 Geothermal
