Honeywell WiFi thermostat RTH9580WF
Ross13
Member Posts: 4
-I posted this in oil heat. I should have posted here.
I have a 2 zone oil heat system. I currently have LuxPro thermostats. The three wires coming out of the wall are the following:
RED - connected to RH
WHITE - connected to W
GREEN - NOT USED (not shown in picture)
BLACK - Jumped between RH & RC
The new Honeywell WIFI thermostat states you need a "C" wire for power. I went down to the Burhnam furnace to check Honeywell board and the GREEN wire is not connected to anything. I also do not see anywhere on the board a "C" to connect to?
Any suggestions. Attached are 3 pictures. In order, Honeywell control board @ the furnace, current LuxPro t-stat, & the new Honeywell t-stat.
Which Burnham?
The wiring diagram will shed light on this.0 -
Burnham Model
Burnham model RS109T-TB
Manufactured in 19980 -
WiFi
Install a switching relay with a Common terminal, ie: Honeywell R8845U.0 -
Switching relay
Ok, so replace the existing panel with a new R8845U?
Or I could always buy a Nest, which doesn't require a "C" wire, although I personally like the shape of the Honeywell vs. the round Nest. I am not a heating guy so I will most likely hire a contractor to replace the relay if that is the only viable option, which it appears to be right now.
Thanks for your help!0 -
Can't make sense out of that number
but it's probably a component ID of some sort. From what I can tell, it was probably part of a V-74. As I write this, Burnham appears to be in the midst of rolling out a major website update and I can't find the manuals I know were there as recently as last week. A competent contractor could no doubt locate a common terminal in there someplace, but it's not something I could recommend you take on yourself.0
- 50 Industry Classes
