Vintage Williamsport Co Radiator with Pictures
Sweet_Lou
Member Posts: 19
I am the fortunate owner of several vintage cast iron radiators manufactured by the Williamsport Radiator Co originally located in Williamsport PA with offices in Philadelphia on 108 S 18th Street and in NYC at 99 Beckman Street. All the radiators say "NORKA" on the bottom and I have attached pictures.
If any one comes across these type of radiators in their travels I would be interested in purchasing some more to add to my collection. I have 12 radiators in my home and 7 are vintage like the pictures attached below.
Has anybody ever seen these Rads before?0 -
I have a house full
I live 30 miles south of Williamsport0 -
Links
Try these contacts
http://www.heatinghelp.com/article/9/Virtual-Trade-Show/236/Searching-for-Old-Radiators0 -
Quite a few made their way to Baltimore
especially to Charles Village-area rowhouses.
Did the Williamsport Co use any other names? I've seen radiators with the name "Koran" and wondered who made them.......All Steamed Up, Inc.
Consulting0 -
The plot thickens
Williamsport Radiator was making both the Norka (2-column only AFAIK) and Koran (3-column version) in 1915:
http://books.google.com/books?id=VR80AQAAMAAJ&pg=PA267&lpg=PA267&dq=williamsport+radiator&source=bl&ots=oHeWQSQjpW&sig=KqHxN20X7JhVaNLLMffK3GiMBIU&hl=en&sa=X&ei=jinTUpqCOsnRsATrpIHgCw&ved=0CCgQ6AEwADgo#v=onepage&q=williamsport%20radiator&f=false
But as of 1922, they were being made by Standard Heater Co of Williamsport. This company also made the Spencer magazine-feed boilers at that time:
http://books.google.com/books?id=Oz08AQAAMAAJ&pg=PA322&lpg=PA322&dq=radiator+koran&source=bl&ots=SVOHHimaIL&sig=YMl_dMuiEjjS8WVIHW6w1bhlkvc&hl=en&sa=X&ei=RirTUt7tFeLjsASS_IKADA&ved=0CF0Q6AEwBQ#v=onepage&q=radiator%20koran&f=false
However, in 1915, Williamsport Radiator was making New Craig and WIRCO boilers, while Spencer Heater Co was making Dandy and Lackawanna boilers, as well as the Spencer magazine-feed boilers that would make that company famous, in Scranton, PA. :
http://books.google.com/books?id=VR80AQAAMAAJ&pg=PA267&lpg=PA267&dq=williamsport+radiator&source=bl&ots=oHeWQSQjpW&sig=KqHxN20X7JhVaNLLMffK3GiMBIU&hl=en&sa=X&ei=jinTUpqCOsnRsATrpIHgCw&ved=0CCgQ6AEwADgo#v=onepage&q=spencer%20heater&f=false
Interesting twists and turns here. BTW, the only boiler I saw in these e-books still being made is- the Smith Mills.All Steamed Up, Inc.
Consulting0 -
nice paint !
beautiful!There was an error rendering this rich post.
I have several.
I enjoy the beauty and the heat from these works of art!There was an error rendering this rich post.
wow.
Stunning detail.Terry T
I obtained this website from an earlier post. It's a radiator manufacturer in England which attempts to reproduce vintage American pieces of art.
http://www.paladinradiators.com/
They must be very expensive to have them shipped to the states but from their website they give a little history lesson as well as display some beautiful vintage rads.
PS: ALIGA love your vintage rad picture! Do you know when your rad was manufactured?0 -
not sure on the year
i have two of them the similar size.
i got one sandblasted, and powdercoated which is the one i took a pic off. It took 4-5 guys to take it down and bring it up my stairs.
i painted one myself, it looks pretty good as well.
i would like to gold leaf the highlights somehow. if anyone has any ideas on how to do that, please let me know.0 -
Gold leaf
Apply the sizing (gold leaf glue) with a hard rubber roller. That way the size only gets applied to the raised details.
However you should talk to a gold leaf expert to make sure the gold leaf can handle the heat. Otherwise you will have to use oil based gold paint. Which BTW I would also paint on the radiator with a rubber roller.0 -
thanks Steve
you hit it on the head, a hard stiff roller is needed so it wont penetrate into the grooves.0 -
Towel Bars with steam
I wonder if you could use their towel radiators for steam - I suspect they might have parts which can't handle the heat.0
- 109 Chimneys & Flues
- 975 Plumbing
- 387 Solar
- 17 Recall Announcements
