Effects of system vacuum on gauges, and vaporstats?
nicholas bonham-carter
Member Posts: 8,578
What stages are the people of the vacuum in at the moment?
Has there been any damage to gauges, or vaporstats?--NBC
no effect
I have run as high as a 10" if vacuum. It has had no effect on vaporstat or gauges.Dave in Quad Cities, America
http://grandviewdavenport.com0
