Bleeder valves stolen!! Grr...
ceciliastar1
Member Posts: 2
we just purchased a new home. 2 days before we closed the copper was stolen. It wasn't as bad as it could be and my husband is a contractor so we decided to purchase the home anyway. The house was built in 1920 and is radiator heating. We are very excited to have this kind of heating! However, we discovered yesterday that not only did they get away with the copper but the "bleeder valves" on the radiators were stolen.
My husband calls them bleeder valves. I don't know anything about radiant heating. I guess these were made of brass and they got away with about 10 of them.
Can anyone point me in the direction of how to replace those parts? I google "bleeder valves" and I don't really come up with much.
Does this make any sense to anyone? I've never dealt with radiators before so I'm not sure what to do. Thanks!!
Vents
Welcome to the world of steam!
They are called Air Vents. Go to any major plumbing supply and ask for Gorton radiator vents. If they try to sell you VariValves, kindly decline and walk out.
You'll want to install small vents on the small radiators and large vents on the large radiators. Do not follow the diagram that Gorton hands out. They make great vents, but have no idea how to install them!0 -
it this...
what you mean? If its a hot water system... http://www.pexsupply.com/Taco-417-3-Coin-Vent-11389000-p0 -
At this point
we need to know if you have a hot water or a steam system.Some pictures of the boiler and near-boiler piping would help.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
okay!
Thanks for the responses so far. The next time I'm in the house I will definitely take pictures! I honestly have no idea if it's steam or hot water, etc.0 -
Vents
My bad. Thought I was in the steam forum!
Easy way to check what kind of system you have.... Look at the boiler. Does it have a clear glass tube? Does it have a circulator?0
- 87.8K THE MAIN WALL
- 129 Chimneys & Flues
- 122 Geothermal
- 79 Pipe Deterioration
- 396 Solar
- 17 Recall Announcements
