Connecting circulators - flanges
Hello - simple question please. I just purchased a Grundfos circ for a wood-fired radiant system that I am building, and there are no instructions as far as how to connect the flanges. Seems simple right? But I obsess over little things. So the O-ring is in between the flanges, but I feel like if I tighten it so that the flanges contact each other - the O-ring will split. So how tight is too tight? Do I go all the way?
  • Snug it up,
    but don't wail on it.  Turn on the water and if it leaks, snug it up some more.
  • OffRoadAudio
    OffRoadAudio Member Posts: 5
    Thanks
    Thanks - I was aiming for that, but wondered if there was a method to it.
  • RobG
    RobG Member Posts: 1,844
    Method
    There is a method to it, and Alan just gave it to you. :)
    Rob
