Connecting circulators - flanges
OffRoadAudio
Member Posts: 5
Hello - simple question please. I just purchased a Grundfos circ for a wood-fired radiant system that I am building, and there are no instructions as far as how to connect the flanges. Seems simple right? But I obsess over little things. So the O-ring is in between the flanges, but I feel like if I tighten it so that the flanges contact each other - the O-ring will split. So how tight is too tight? Do I go all the way?
Snug it up,
but don't wail on it. Turn on the water and if it leaks, snug it up some more.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
Thanks
Thanks - I was aiming for that, but wondered if there was a method to it.0 -
Method
There is a method to it, and Alan just gave it to you.
Rob0
- 121 Chimneys & Flues
- 15.8K Strictly Steam
