Second shutoff for boiler on stairs?
ChrisJ
ChrisJ Member Posts: 17,117
So my wife accidently shut the boiler off again instead of the basement lights.  This has only happened a few times but it is really annoying.
I want to remove the switch and put a blank plate but I want to make sure Its not violating code if I do.  I recall a few saying having the switch there for a gas burner may actually be against code in some areas but I want to make sure I am remembering correctly.  I of course have a shutoff right on the side of the boiler.\
  • Bob Harper
    Bob Harper Member Posts: 1,145
    disconnect switch at CAZ entry
    Required for oil under NFPA 31--not required for gas.
    ChrisJ
  • ChrisJ
    Thank you
    Thank you for responding.
    I'm glad to see it isn't required and I may also consider just using the switch guard as it would allow me to shut it off if I want to without going down the stairs.
    The good news is I only saw 6 oz PSI during a 6 degree recovery with a 20F ambient and now the house is nice and warm. Did I ever mention how much I love steam heat?
  • JohnNY
    JohnNY Member Posts: 3,344
    It's required for gas where I live.
    That's in NYC.
    Consulting & Troubleshooting
    Heating in NYC or NJ.
    Classes
    ChrisJ
  • JUGHNE
    JUGHNE Member Posts: 11,515
    Switch
    A 1" 2 hole EMT strap (electric conduit/tubing) fits the screw spacing pretty well for the switch cover.  That is what I use for switch guards. Maybe 20 cents or less.(Might need small washers depending upon the strap hole size).
    Steamhead Member Posts: 18,280
    I like these
    since it also lets you lock the switch out:
    http://www.garvinindustries.com/locking-mechanisms/toggle-locks
    Consulting
  • Rich_49
    Rich_49 Member Posts: 2,785
    Keep
    the switch and use the guard . It is code in many jurisdictions to have it there . better to have it and not need it than to need it and not have it .
    732-751-1560
    Rich McGrath 732-581-3833
