Hartford Loop
Evo1
Member Posts: 1
What happens if the Hartford Loop is above the water line?
you will have
You will have a free hammering rock concert.. well , not so free if you already have it done..0 -
Giffords loop
Unless you use a Gifford loop but that must be done a certain way as well and I believe there is a lot you have to take into consideration.
You can find info on a Gifford loop in this thread. http://www.heatinghelp.com/forum-thread/127507/Just-because-its-been-that-way-for-yearsSingle pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
