SPENCER RF 240 steam Boiler
Mike20
Member Posts: 37
Hello fellow Boiler people
Can any one tell me the BTU input rating of this Old Girl
SPENCER RF 240
It is a Low pressure steam, steel, fire tube boiler currently burning #2 Oil and it is a Monster
I am looking to replace and Down size to a nice 3 pass federal Boiler
The building is 24 apartments and 21,000 square Ft located in the Bronx, NY
Thank you
Mike G
SPENCER RF 240
Thank you
Mike G
Sizing an old boiler
Is this 1-pipe, or 2- pipe? Are you restricted to oil?
Are you planning this for next spring, or must it be installed ASAP?
Can you size the new one from the radiation EDR, as relying on what was there before may result in repeating someone else's mistake.--NBC0 -
Evaluated?
Have you had the current boiler evaluated by a boiler repair specialist? By that, I mean someone who is qualified to repair a fire-tube boiler. The reason that I ask is that these old beasts can often keep on going past the 100 year mark. The expendable part are the tubes, and re-tubing a boiler is not that huge of a deal. The rest of the beast is very heavy plate steel and may be in very good condition. You never know unless you have it evaluated by a qualified professional.
The good thing about a fire tube boiler is their efficiency. With a finely tuned burner and turbulators inserted in the flues, you are going to have an efficiency in the 80-85% for sure. Also, you generally can down fire this type of boiler as much as 50% with no loss in efficiency.
As for the INPUT rating that you are looking for, that boiler should be rated in H.P., Horsepower. See if you can find that and someone here will work out the conversion. Of course, if you are working on the question of sizing the new boiler, a complete survey of the radiators in the building is what you need to do.Dave in Quad Cities, America
http://grandviewdavenport.com0
