Air in convectors
Steamer30
Member Posts: 8
I have a low pressure steam boiler that uses convectors housed in the wall to spread the heat. They have a thermostatic operator and a B&J thermostatic angle trap on them. Somehow air has gotten into the system and is stopping heat from entering convectors. Keep in mind they are not cast iron radiators where I can drill and air vent in on the side. So my question is - how do I bleed the air out?
Convector problem
At rest, there is always air inside a steam system, and with good venting, the air will escape with little or no resistance (back-pressure).
This seems essentially like a 2-pipe system, with traps at the return end whose job is to let out air, and water. They should not have radiator vents on them.
Trace out the supplies and returns, looking for a sag which is pooling water, and stopping the air from escaping. Look for a cross over trap which has failed.
If the boiler is throwing up water, then that will exacerbate the problem, so post some pics of the boiler and it's piping.--NBC0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
