which boiler
tmc
Member Posts: 12
I have 142 square feet of radiation not including main, which boiler should I use burnham pin3 or pin4?
PIN3
Remember, the sq ft rating on the boiler already had the 34% piping loss and pickup factor figured in. Assuming that you have insulation on your mains in the basement, 34% is plenty. The PIN-3 has a rating of 163 sq ft giving you a little room to spare. Remember, vent your mains quickly and your radiators slow, but completely.Dave in Quad Cities, America
http://grandviewdavenport.com0 -
which boiler
mains aren't insulated ,app 40'of 2" main, I used dan's formula 142x1.5 =213 213x240=51,120. I know it's close, what would you do? pin3 has doe rating of 51,000, pin 4 is 87,0000 -
anybody but
Anybody but Junkirk boiler0 -
that is very close
When you compare 51,120 to 51,000, it for these purposes the same number. The difference is two tenths of on percent, or 0.2% You could not get a boiler that was closer matched. The 50% piping and pickup factor gives you extra margin already. If you go with the larger boiler, it will be over sized and will not work well.Dave in Quad Cities, America
which boiler
thanks dave.going with the 30
- 85.7K THE MAIN WALL
- 49 Biomass
- 73 Chimneys & Flues
- 92 Geothermal
- 150 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 851 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
