Need to add radiator to bedroom
ChadZeilenga
Member Posts: 12
I have an old victorian home that was originally steam, but is currently set up as a hot water boiler system. I have a bedroom on 2nd floor that does not have any heat. I'm not sure why since the other bedrooms do on 2nd floor. The bedroom below on 1st floor has a radiator that could be tee'd off from to pipe up to 2nd floor. I think it had a wood stove that went into the chimney access?
My question, is who should I call to have the radiator installed. Would it be a Boiler service company, or a plumber? I'd prefer someone who could help me size the proper radiator for the room. I'm south of Chicago in Crete, IL.
"Find a Contractor" maybe?
http://www.heatinghelp.com/professional/105/The-Steam-Whisperer-Boiler-Professionals-Inc
only one listed there apparently.0
- 167 Indoor-Air Quality
