Non barrier tubing
greenhead_2
Member Posts: 13
I have a 1000 feet of non barrier tubing in a floor and it is going to
Heat by a cast iron electric boiler . Is there any thing
I can do without adding an extra pump and heat exchanger
NonFerrous
Pumps, and components is the only way unless you isolate via HX. I would use an HX other wise your CI boiler is going to live a short life.0
- 50 Industry Classes
