modular steam boilers for multifamily hi-rise
Nusselt
Member Posts: 1
I am looking at a boiler upgrade for a multi-family hi-rise that currently has a 200 BHP oil-fired (No. 6) fire-tube boiler with two-pipe steam distribution. Fuel conversion is definitely on the table, and I am considering No. 2 diesel, biofuel blends, and natural gas.
I also want to look at the possibility of replacing this fire-tube boiler with several modular boilers. I have read Dan's article on the importance of near-boiler piping and isolation on the return side, but I would like the benefit of others' experience. Does anyone know of case studies that are available, or do you have direct experience with such a conversion that you could relate?
Also, is anyone aware of any additional challenges that a modular steam system might present for installation in NYC?
For case studies...
...your best bet is to contact Con Ed's Gas Conversion Group and see what they have available:
Tel: 1.800.643.1289Contact John "JohnNY" Cataneo, NYC Master Plumber, Lic 1784
Consulting & Troubleshooting
Heating in NYC or NJ.
Classes0 -
Most manufacturers
will have case studies and piping arrangements for modular steam systems. Most of the problems I have encountered are due to contractors not following the manufactures recommendations.
Good Luck,
Timothy Hodgson0
- 167 Indoor-Air Quality
