triangle smart tank and solo
plumbgod
Member Posts: 9
I have a customer and he says that in normal space heating the boiler is at 15-20 psi and when a call for DHW it drops 5 psi. Any ideas on this??? Please put input in. thanks
One possibility
the DHW pump is oversized and pumping away from the pressure gauge.0 -
good point
that is kind of what i was thinking. Just moving way to fast though it. I will see if it sized correctly. any other ideas by chance?0
- 116 Geothermal
- 169 Indoor-Air Quality
