triangle smart tank and solo
I have a customer and he says that in normal space heating the boiler is at 15-20 psi and when a call for DHW it drops 5 psi.   Any ideas on this??? Please put input in.   thanks
  • SWEI
    SWEI Member Posts: 7,342
    One possibility
    the DHW pump is oversized and pumping away from the pressure gauge.
  • plumbgod
    plumbgod Member Posts: 9
    good point
    that is kind of what i was thinking.  Just moving way to fast though it.  I will see if it sized correctly.  any other ideas by chance?
