aquastat setting
hairball
hairball Member Posts: 19
I have two aquastats. One maitains the maximum temp of the water in the furance the other wont let the thermostat in the living room turn on the ciculator pump unless the water temp in the furance it at a minumum temp. what should the second aquastat be set at?
Thank You
Chris
  • there are no
    There are no aquastat(s) on furance.. only boiler
  • hairball
    oops
    My bad. Boiler then
  • hairball
    Delta t
    Belive its calle the delta t. It maintains a minumum returune temp of the water.
  • Ron Jr._3
    Ron Jr._3 Member Posts: 605
    What model number is the aquastat ?
    And is the boiler making hot water with a coil ?
  • hairball
    edited October 2013
    hot water
    Its and old richardson hot water boiler. No coil. Sorry all I can tell you is they are Honywell aquastats. You can see them at the top of the middle picture. They dont have the covers on them.
  • Robert O'Brien
    Robert O'Brien Member Posts: 3,584
    20*
    A minimum of 20* less on the B aquastat,in reality with that POS you don't even need it!
  • billtwocase
    billtwocase Member Posts: 2,384
    aquastat
    Ever work on a Waterair? They had them
  • gennady
    gennady Member Posts: 840
    edited October 2013
    dual setting aquastat
    hi is a boiler limit, set at 180, lo is to prevent condensation, set at 140. lo is preventing circulator from pumping constantly cold water trough the boiler. it allows to heat portion of the water at the time.
