Thermostats
Andrew boiler
Member Posts: 44
If I set my thermostat to 68 will it stay at 68 ?
Iafter the heat is done heating will it be saying 68?
Constant temperature
When the temperature begins to drop below the thermostat set point (68 deg), the boiler is energizes, to come on. When the temperature approaches the set point, the circuit is broken, and the boiler will stop firing.
The thermostat must be located on an inside wall, in an area where it is not exposed to a cold blast of air, every time the outside door is opened, digital thermostats are easier for the average homeowner to operate, as they enable the settin to be changed by one degree, which can make all the difference.--NBC0 -
Thank you
Thank you you weere a big help0
- 167 Indoor-Air Quality
