Buderus G205....
kcopp
Member Posts: 4,588
in Oil Heating
What has been your guys experience w/ these in the field. Buderus discontinued these a good while back but Im sure there a a bunch out there.... do they set up ok? run ok? clean well?
G205
The G215 replaced the G205. Same interior design, different cabinet design, & the door can be made to swing either way on the 215. Other than that, great boiler. I have one in my in my house and 2 used ones in my garage, that I recently purchased at a very reasonable price. All three units have Reillo burners and burn very efficiently, high 80's. The 205 & 215 are triple bypass boilers and are very easy to clean, no heat transfer pins to get brushes stuck in. They are a very good unit.0 -
thanks...
that is a bit helpful. I was asking because I see a used one for purchase.0 -
Buderus Tag
G = Cast
2 = Output size
0 = Revision
5 = Burner Type (power or atmospheric)0 -
Used G205
It depends on the condition of the boiler, burner & components, and what exactly I get with the purchase of the boiler, what I would pay. For example, the last used G205 I purchased was in excellent condition, housing was not all bent and scratched, oil burner had all new parts (motor, fuel pump, control, capacitor, nozzle & electrodes), backflow preventer, water fill valve, 17 gallons hyrdronic anti-freeze, all 1 yr old. B&G 100 circulator, expansion tank, aqua stat, fuel filter, flow control valve, 1-1/4" copper & paperwork, all for $300. I got a great deal, but I wouldn't have given much more.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 163 Indoor-Air Quality
- 71 Pipe Deterioration
- 6.4K Radiant Heating
- 393 Solar
- 55 Water Quality
- 46 Industry Classes
