Riello Burner Call but no action
cyrscot
cyrscot Member Posts: 1
I have a Riello F3 Burner. Turned the heat on last night and the call to the boiler worked, the fan to the air handler kicked on and the circulator began running. The burner icon lit up on the Slant Fin Eutectic SF10 Control but nothing at the burner happened: no fan for pre purge, no pump, and most important no fire.
120v at the burner so there is power.
Any ideas?
  • Ron Jr._3
    Ron Jr._3 Member Posts: 605
    Is the reset button lit up ?
    Press it in and see if it cycles . If it goes out again I'll guess it needs a tuneup . Does the boiler make hot water with an indirect heater too ?
