primary/secondary
Paul S_3
Member Posts: 1,291
When using a regular atmospheric hot water boiler with primary/secondary piping....how do I control the primary pump? System is going to have four high temp baseboard zones.....and three radiant zones with 3 way mixing valves.....should that I use a relay to turn primary pump on whenever any zone call for heat or outdoor reset Paul s
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
347-692-4777
ASMHVACNYC.COM
The easiest way
is to wire it off the boiler if it has a pump relay.
If not, create you're own pump relay off the end switches as you say.8.33 lbs./gal. x 60 min./hr. x 20°ΔT = 10,000 BTU's/hour
primary/secondary
Do you recommend one pipe primary secondary or two pipe on a residential home? Heat loss of home about 160000btuh's...thanks Paul sASM Mechanical Company
347-692-4777
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company0
- 167 Indoor-Air Quality
