Poor Mans Insulation
ALIGA
Member Posts: 194
started the boiler room insulation with r30 fiberglass and duct tape.
before:
after
before:
after
Please note
The Kraft paper on that is not fire rated and poses a risk of spreading fire. Also note compressed insulation has very low R rating.Cost is what you spend , value is what you get.
cell # 413-841-6726
thank you Charlie
kraft paper has been removed, replaced with foil tape.0 -
Compressed
But do you still have R30 compressed down to something like R5?
In order for R30 to be R30 it must be its full expanded thickness.Single pipe 392sqft system with an EG-40 rated for 325sqft and it's silent and balanced at all times.
Give me a flippin break.
Why don't you just use the proper stuff.gwgillplumbingandheating.com
What's wrong
I have read people doing the same on the forums. Plus I had extra batting laying around.
It is a pain to wrap. I have about 40 feet if mains to cover, I will go ahead and order the pipe insulation in 1 inch.0
- 119 Chimneys & Flues
- 165 Indoor-Air Quality
- 76 Pipe Deterioration
- 15.6K Strictly Steam
