Poor Mans Insulation
ALIGA
ALIGA Member Posts: 194
started the boiler room insulation with r30 fiberglass and duct tape.
before:
after
  • Charlie from wmass
    Charlie from wmass Member Posts: 4,422
    Please note
    The Kraft paper on that is not fire rated and poses a risk of spreading fire. Also note compressed insulation has very low R rating.
    cell # 413-841-6726
  • ALIGA
    thank you Charlie
    kraft paper has been removed, replaced with foil tape.
  • ChrisJ
    ChrisJ Member Posts: 17,060
    Compressed
    But do you still have R30 compressed down to something like R5?
    In order for R30 to be R30 it must be its full expanded thickness.
  • gerry gill
    gerry gill Member Posts: 3,083
    Give me a flippin break.
    Why don't you just use the proper stuff.
    gwgillplumbingandheating.com
  • ALIGA
    What's wrong
    I have read people doing the same on the forums. Plus I had extra batting laying around.
    It is a pain to wrap. I have about 40 feet if mains to cover, I will go ahead and order the pipe insulation in 1 inch.
