pex
Paul S_3
Paul S_3 Member Posts: 1,292
can anyone tell me the max GPM allowable through pex tubing for example: 1/2'', 5/8'',3/4'' & 1''....thank you PAUL S
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
  • SWEI
    SWEI Member Posts: 7,348
    As usual, it depends
    Mostly on the application, more specifically the fluid type and velocity or head limit.
    Appendix G of the Uponor CDAM has a comprehensive set of tables.
