radiant heat loss calculation?
Paul S_3
Member Posts: 1,288
Hey everyone....when doing a heat loss calculation on a home that will be using radiant heating (staple up job) can I use a regular heat loss calculation that I would use on a baseboard job for example Slant Fins heat loss express? Or is there another calculation specifically for radiant heating thank you Paul S
ASM Mechanical Company
Located in Staten Island NY
347-692-4777
ASMMECHANICALCORP@GMAIL.COM
ASMHVACNYC.COM
https://heatinghelp.com/find-a-contractor/detail/asm-mechanical-company
347-692-4777
ASMHVACNYC.COM
Yes
Heat loss calc only calculates the amount of heat needed(or heat lost) to warm a room/building. It doesn't matter what system you tend to use in your house as it doesn't take any of that into consideration.0
- 87.1K THE MAIN WALL
- 58 Biomass
- 114 Chimneys & Flues
- 110 Geothermal
- 161 Indoor-Air Quality
- 999 Plumbing
- 391 Solar
- 55 Water Quality
- 45 Industry Classes
